[5th Gen : 08+]: 62te transmission flush details
Old Jun 5, 2018 | 09:04 PM
tombj's Avatar
tombj
Default 62te transmission flush details
I want to flush the 62te trans in my '11 caravan, just wanted to confirm the hose on the trans with the WHITE cap is OUT of the trans TO the cooler, correct? So I can pull the other line with the black cap at the trans, clamp a clear hose on that line end where it was plugged in to the trans and put it in a bucket for flushing, correct? I'm expecting to pull that line, drop the pan, replace the filter, refill with 4-5 qts or what ever gets me about a 1/4" on the dipstick, start the engine & run while adding what I'm losing from the hose until I get 5 qts in the bucket or clean fluid, which ever comes first, then reinstall the return line to the trans, and adjust the level correct based on the fluid temp chart. Am I missing anything there?
