[4th Gen : 01-07]: When slow down, engine shuts off
Old Aug 31, 2018 | 09:26 PM
georgi's Avatar
georgi
Default When slow down, engine shuts off
This happened several times for a month. The caravan (2001, 4 cyl), is doing it at the parking lots, when making maneuvers back and forth. There is no interruption in the engine or misfiring. The transmission and fuel filter were replaced 3 years ago (30000mi). Now put injector cleaner in the fuel but I doubt it might be the cause. No A/C on at that time. They could be several different reasons. Any experience?
BTW, what is the lifespan of rebuilt transmission for Dodge caravan? I heard ones 50000mi.
Old Sep 1, 2018 | 01:01 PM
primem's Avatar
primem
life of a trans can vary greatly depending on maintenance, use and abuse, towing. I've seen many taxi caravans come into the shop with 300 000kilometers on the original trans. This is incredible as the constant stop starts of intown driving wears the clutch packs.
for your stalling issue...check engine light on; if yes post the codes.
-vacuum leaks can cause this...check the fuel trim. if it uses a idle air control valve...If the valve is bad, its hard to transition from closed throttle to open
-perform a throttle body clean and see what happens
