[4th Gen : 01-07]: headlight problem
Old Sep 6, 2018 | 11:13 PM
granie's Avatar
granie
Default headlight problem
headlight problem.I drive a 2002 grand caravan, when the daytime driving lights are on, only the driver's side works, turn the lights on, drivers side goes out and the other one comes on. Turn the high beams on, and it switches again.Doesn't matter what you do, only one of the two light are on. Have tried replacing the bulbs, but same thing happens
. Was driving one day in the dark with only one passenger light on and then all of a sudden both lights came on and stayed on for the remainder of the trip home (or at least I thinks so). but the problem returned the next time I drove. I read on another forum that problem is in the front control module. Can anyone help me out in trying to solve my problem. Thanks
Old Oct 26, 2018 | 01:15 PM
banjo_d's Avatar
banjo_d
the problem is the ECM. I had the same issue. I found a thread where the person suggested to remove it, clean the contacts and try it. When that (if that) doesnt work, he suggested to turn the pins CARERFULLY with some needle nose about 1-2 degrees. just to make the contact a bit stronger. Worked for me, no issues 3 years later.
