[5th Gen : 08+]: Tipm head ache
replace tipm on 08 Caravan se dashboard brake light on when van start to warm up so I was told I had a bad abs module that’s why abs lights on and brake also that bell was out of a lot of money you think I should invest in a abs module help me someone if you can???
impossible to say based on the information you provided.
if the abs light and brake warning lamp are on, a dtc will be set in the abs module. this code is the starting point for diagnosis. have the module scanned with a scan tool that can read chassis codes and post the codes here. a cheap code reader will not access chassis codes...you need a scan tool that can access the abs module.
it could be something like a open wire to the brake fluid level sensor at the reservoir...have the code checked and report back.
