convert 12V rear outlet to full time power "on"
Old Dec 12, 2005 | 01:56 PM
jeffl's Avatar
jeffl
Default convert 12V rear outlet to full time power "on"
I have 2001 Caravan with the rear power 12V outlets. These are tied to the key switch, but the manual states that they can easily be converted to be powered directly from the batter, but "see dealer". Has anyone covertered these? I think it requires replacing a relay (tied to the ignition) with just a jumper or fuse from the dealer. Just wondering?
I'm tryhing to keep the portable electronics running when stopping for fuel, etc.
Thanks,
Jeff
Old Dec 13, 2005 | 10:00 AM
brandoncrone's Avatar
brandoncrone
Default RE: convert 12V rear outlet to full time power "on"
In the underhood fuse box you will see on the inside of the lid I believe a picture of a battery and a key. It corresponds to a large fuse on the fuse box. All you have to do is move the fuse over one position and that is all. Since it said see dealer in your manual, where would you like me to send the bill for $43 that the dealer would have charged?
Old Dec 24, 2005 | 06:13 PM
jeffl's Avatar
jeffl
Wow! You were right, it was right there under my nose. I moved it and it worked.
THANKS SO MUCH!
Jeff
Old Mar 12, 2013 | 02:51 PM
td1's Avatar
td1
will this SIMPLE process work with the FRONT lighter/outlet as well? i have a 1996 GC, ES, 3.8L
thanks!!
td1
Old Mar 16, 2013 | 01:23 AM
td1's Avatar
td1
ok.....got the aux power socket and usb socket installed in the rear armrest compartments of the 96 3.8L hippievan. also got the new headlights installed too (whole unit, not just bulbs).
drivers left is the dual usb sockets. awesome.
drivers right is the power accessory socket. awesome.
installs took about 3 hours. not bad. skiKation, bring it on!
td1
