[General]: Lost Throttle and Power Steering!
Old Apr 12, 2019 | 10:52 AM
ACM's Avatar
ACM
Default Lost Throttle and Power Steering!
I just bought a 2014 Dogde Caravan and twice within 3 days the accelerator and power steering stopped working while driving. Luckily I was I a good spot to pull over. I took it to the machanic under my service plan who then took it to a dodge machanic and both of them are saying nothing is wrong. I know what happened and I know it could end up putting me in a real serious situation like on the freeway. What do I do.
Old Apr 12, 2019 | 11:53 AM
Sounds like it shut off. Did they scan for codes? Unless you can replicate the issue, it is hard for anyone to diagnose it. Start with a basic tune up.
Old Apr 12, 2019 | 01:07 PM
ACM's Avatar
ACM
They said they took it for a test drive and ran a diagnostic and nothing came up. This doesn't happen every time we drive it so I would imagine they have to take it for a few test drives. I don't know what to do, this could be potentially dangerous if I'm on the freeway and whole reason we got the thing was for long distance trips.
Old Apr 13, 2019 | 09:00 PM
GumbyRT's Avatar
GumbyRT
Unfortunately you may have to wait until it happens again for the problem to be diagnosed- intermittent malfunction can be difficult to nail down for even the most seasoned technicians.
I agree it sounds like the van shut off, so here’s some basic things to check that could cause it:
1) Clean and tight Battery cable connections at the battery, starter, fuse box and primary body and engine grounds.
2) Connections at the alternator.
3) If it’s not a push button start, start the van in the driveway and wiggle the key to see if the van dies. This checks for a loose ignition switch.
