[3rd Gen : 96-00]: Removing plenum for 2000 Dodge Grand Caravan sport 3.3 flex fuel
Are there any step by step instructions out there for removing the plenum to change the spark plugs? I got as far as being able to move the plenum, but it is still attached by a wire harness in the back of the plenum that I can't see well enough to tell how to disengage it. Any help would be appreciated. I am a VERY novice weekend mechanic! Thanks!
Put a couple bolts back in place to hold the plenum steady, then use a mirror or phone camera to see what it looks like. Once you see it you can try disconnecting it by feeling where your hands and fingers need to be positioned.
If it’s attached to a sensor, you can also try removing the sensor from the plenum, then once the plenum is off, disconnect it and reinstall it before you bolt the plenum back on.
