Dodge CaravanThe Dodge Caravan is the best selling mini van from Dodge. How many Dodge Caravan owners here at DodgeForum.com would agree? Discuss it now!
Weak alternator, bad/dirty connections, weak battery. Get the charging system tested. Most auto parts stores will do this for you if you don’t know how. Or, if you have a volt meter, measure your battery voltage with the engine running, should be around 14.5 VDC.
