[3rd Gen : 96-00]: Need help on where I start diagnosing codes po202 and po201 for 98 caravan 3.0 litre
Old Jul 22, 2019 | 07:10 PM
Wadd's Avatar
Wadd
Default Need help on where I start diagnosing codes po202 and po201 for 98 caravan 3.0 litre
Need help to fix this problem where do I start I'm not experienced with this area need help explained simple as possible I would appreciate it.
Old Jul 22, 2019 | 10:11 PM
GumbyRT's Avatar
GumbyRT
Edit: If you read my original post, disregard it. I misread the codes as starting with P03 (misfire) not P02 and posted my response based on that. Sorry for the mistake.
P02 codes indicate the fuel injectors as the problem. The most efficient diagnosis would be to swap the 2 injectors from the the faulty positions (cylinders 1 and 2) with injectors from 2 other cylinders. If the codes follow the injectors, they need to be replaced. If not, the control side (wiring and PCM) need to be diagnosed.
That said, I stand by my original recommendation to take it to a shop if you’re not comfortable doing this.
