[5th Gen : 08+]: Strange knocking sound
Hi guys
I am getting a weired knocking noise coming from the glove compartment. If the A/C is turned on when I start the car there is a rhythmic knocking sound for 10-15 seconds and then it stops. If the the AC or heater is turned off when I start the car, there is no knocking but as soon as I turn it on, the knocking ensues for 10-15 seconds. The only other time the knocking occurs is after the car has been turned off; after 2-5 minutes, the knocking starts and lasts for 10-15 seconds. Does anyone have any idea what might be causing this knocking and/or what needs to be done to fix it? Thanks!
the hvac unit has 3 or 4 actuators that move the mode, temp and recirculate doors. when the linkage is broken the doors move out of a calibrated range...the clicking is the hvac module calibrating the door range....as it moves from completely closed to open. inspect the hvac actuators behind the glove box
Hi guys
We certainly understand why this would be concerning. If you’re not able to determine the cause based on advice provided here, we kindly recommend connecting with your local Dodge dealer as they are in the best position to assist. Our team is available via private message if you are in need of any assistance with that process.
Mark
Dodge Social Care Specialist
