[5th Gen : 08+]: What Size Spare for 2014 Caravan?
Without a factory spare tire on my 2014 Grand Caravan SXT, I bought run-flats for my last tires. They didn't hold up well so now I want to get regular tires and get a compact spare. On the underside I already have the spare tire winch and covers. From a recycle yard I got a spare but the lug configuration is wrong. Can someone tell me what size spare I should be looking for? The one I have that is wrong came from a 2012 Town & Country and is marked T135/70016. I don't find spare tire specs in my manual or on the door post and I don't want to get the wrong one again. Thanks.
Almost forgot...if I can't find one from a 2014 Caravan, what other years or models would have the same size spare?
Have you tried looking in the owners manual? I’ve done some searching but all I’m finding is the rim without a tire (rockauto.com, allmoparparts.com) or there’s spare tire and wheels together but still no listed size.
Thanks. Yes I checked the owners manual as well as the door jamb sticker. I even went to the part dept at my dealer. They could not find a way to order the spare without the whole kit nor could they find a tire/wheel size. I have learned from 1010tires.com that I need a wheel with a 5 x 127mm bolt pattern and hub bore of 71.5mm. From FactoryChryslerParts.com I found a list of Dodge models that use the same size spare.
