Dodge CaravanThe Dodge Caravan is the best selling mini van from Dodge. How many Dodge Caravan owners here at DodgeForum.com would agree? Discuss it now!
2010 caravan has a leak from a fuel line that is visible coming down from the top of the fuel tank at the rear and at this point there is an elbow connector , it is leaking here ( quite significantly ).
Anyone else had this ? I have searched and have found no other cases. it is a nylon line connecting to another nylon line . Maybe the o ring in the connector is deteriorated ?
I can find no replacement parts, I am assuming this line goes above to the fuel pump.
I can find no repair kits that are compatible . Any ideas what to do with this ?
Thanks for any suggestions
Sorry to hear about your leak concerns! If you decide to have this looked into by an authorized dealer, we're available PM for additional support.
The details on the lines are kind of hard to see, but here’s a couple diagrams of the fuel tank area. Are you able to highlight/circle the connector you’re talking about?
Actually, I was looking at it wrong - it looks like ( in the second diagram ) the line on the left (drivers side ) going over and down the front of the fuel tank, when it reaches the level of the bottom of the fuel tank there is an elbow and a connection. The leak is here.
Is this the type of fitting you have? The only things I can think of causing a leak here would be the o-rings being damaged/degraded (as you suggested), the fitting coming loose for some reason, or the line being broken/damaged.
Other than visual inspection there’s not really any way to determine why it’s leaking, so you may have to disconnect it to inspect the o-rings. Wear safety glasses and/or rubber gloves when you do because even a depressurized line can spray fuel when it’s opened up.
If you can, post a picture if you don’t see anything obvious.
It is similar, it has a slightly different retainer, I will try to get a picture. I had already tried disconnecting it and re connecting, it leaks as before. I couldn't see if there is a damaged o ring in the fitting.
