[1st Gen : 84-90]: is VR internal or external to alternator ?
Old Oct 23, 2019 | 01:44 PM
Caravan84-2.2L's Avatar
Caravan84-2.2L
Default is VR internal or external to alternator ?
Concerning the 1984 Dodge Caravan with 2.2 Liter engine -->
- is the Voltage Regulator INTERNAL or EXTERNAL to the Alternator ??
- Any idea if these replacement parts sold by AutoZone will actually work ?
https://www.autozone.com/batteries-s...03z/918286_0_0
https://www.autozone.com/batteries-s...83333_940503_0
AutoZone website says they work with this year of Caravan.
I suspect the Regulator or Alternator, because ammeter shows a strong discharge (far left) when headlights are on, but zero (center position) when headlights are off. Thanks.
Old Oct 24, 2019 | 01:55 PM
GumbyRT's Avatar
GumbyRT
It appears to be external, however, if your van is running fine without the headlights on, it sounds more like a potential short to ground in the headlight circuit.
With the engine running and ALL accessories and equipment off, check voltage at the battery - it should be 13 volts +/- 0.3 volts. Then turn on everything you can except the headlights (radio, ac, maybe engage the cigarette lighter or plug in a cell charger) and see what the voltage at the battery reads - it should be higher than the first reading.
If it’s higher, the VR is not likely the problem. Try disconnecting the headlights on both sides - if it still draws down the system voltage with the headlights disconnected, it’s most likely a problem in the wiring.
