Dodge CaravanThe Dodge Caravan is the best selling mini van from Dodge. How many Dodge Caravan owners here at DodgeForum.com would agree? Discuss it now!
Yes, turn the key to the "On" position, which is one click before the "Start" position, and depress the accelerator pedal three times (or five?) to the floor within five seconds.
You won't. I usually repeat the procedure several times to increase the odds of it actually resetting.
Strange set-up, you would think there would be a way to check oil life etc and know if it's been reset. Maybe they assume everybody drives until the light comes on. Thanks for the info 😁
The oil life can be read with a professional grade scan tool, and I’ve seen several Dodge/Chrysler vehicles that allow you to view it using the driver info center. Unfortunately there doesn’t seem to be any real rhyme or reason to when they decide to put those options on the info center (I’ve seen it on trucks, cars and other vans that are all within 1 or 2 years of mine and have identical driver info centers and instrument clusters).
I have a 2016 GC and I contacted Dodge customer care to ask if it could be reprogrammed to allow me to view it and a couple other things. They said it couldn’t be, which I don’t believe but I don’t have the time or energy to pursue it so I just let it go.
Unfortunately Chrysler oil monitor is pretty lame compared to others I've own quite a few GM vehicles and their oil monitor show the remaining oil life percentage upon an oil change when reset it goes to 100% as the vehicle is being used the oil life automatically start to diminish. Then it allow the owner to decide when he wants to change his oil based on the remaining oil percentage like maybe 25%. When the oil life percentage reaches 15% a Change Engine Oil Soon message will appear at every start if ignored at 0% a Service Due Change Engine Oil message will then appear instead.
