[5th Gen : 08+]: Wheel lock help
Old Mar 9, 2020 | 07:39 PM
Lucas Hart's Avatar
Lucas Hart
Default Wheel lock help
Help. I purchased a used Dodge Grand Caravan from a dealership over 3 hours away. I went to rotate the tires and the back two wheels have these lug locks. The oil change place said if they cut them out it would be costly. The van did not have the key anywhere inside. I called the dealer and they said they could get it off but I don’t want to drive 6 hours to get them off. I tried buying a set of McGard from Amazon and they were the wrong size but looked alike in the picture. Help please.
Old Mar 10, 2020 | 01:22 AM
master tech's Avatar
master tech
Site Moderator & Tech
Go to a dealership and ask if the have a master lock kit that may work. Also another way if the side of the lock doesn't rotate you can use an impact socket and tap it on with a hammer.
