[4th Gen : 01-07]: A used transaxle for my 2005 2.4 L Caravan
Old Mar 13, 2020 | 09:40 PM
Rockdoc's Avatar
Rockdoc
Default A used transaxle for my 2005 2.4 L Caravan
The transaxle on my 2005 Caravan (2.4L 4 Cylinder) after 265,000 miles recently failed. Since the engine still runs great and the car is in overall good shape I’m planning on replacing the transaxle with a low mileage used transaxle from the wrecking yard. According to my research, my 2005 4 cylinder Caravan takes a 40TE transaxle (as do similar Caravans made between 2003-2007). A few of the other vehicles listed that take the same transaxle are:
2003-2010 PT Cruiser
2003-2006 Chrysler Sebring
2003-2005 Dodge Neon
2003-2006 Dodge Stratus
When I went to the local wrecking yard I was told only a transaxle from a similar 4 cylinder Caravan would work. Naturally I’m skeptical, does anyone here know for a fact what kind of vehicle(s) my 40TE transaxle can come from and still work in my Caravan without problems.
Thanks in advance for any guidance you can give me.
Steve
Old Mar 17, 2020 | 02:00 AM
master tech's Avatar
master tech
Site Moderator & Tech
The internal parts would be the same. But the case and torque converter may not. Have you try checking with Rock auto? On a transmission.
Old Mar 19, 2020 | 10:49 AM
Rockdoc's Avatar
Rockdoc
The torque converter and case dimensions are what has me worried. I checked Rockauto but couldn't find anything. Thanks for your post, I appreciate the help!
Steve
Old Mar 19, 2020 | 03:14 PM
Mopar340's Avatar
Mopar340
Chrysler like all car manufacturer uses model numbers for their parts a 40te transaxle are all similar in size and dimension they don't have different variation of the same model of transmission for inventory purposes and replacement parts. The 40te was use on various models that used the inline 4 cylinder FWD engine the torque converter and gear ratio should also be all the same. Anyway most junkyards around here will let you bring things back and return your money if it doesn't fit or work for any particular situation.
