[4th Gen : 01-07]: No power at all
Old Mar 19, 2020 | 05:27 PM
unxpected's Avatar
unxpected
Default No power at all
I知 having an issue with my 2006 grand caravan. I put the key in and there is no power generating at all to the vehicle. The battery is brand new so is the alternator. I知 at a loss right now we thought it was a ground issue but even with an new ground word it doesn稚 work.
Old Mar 21, 2020 | 10:32 PM
master tech's Avatar
master tech
Site Moderator & Tech
Does the dash lights come on when you turn key to start? It could be ignition switch or TIPM module. I would need more information to help.
Old Mar 30, 2021 | 06:20 AM
Nikki Lynn's Avatar
Nikki Lynn
Default Mine has no lights
My van has no lights on the dash when I put the key in the ignition switch nothing turns on
Old Jul 24, 2021 | 10:29 PM
hanere's Avatar
hanere
did you figure out what was going on? We have the same vehicle with the same problem.
Old Jul 25, 2021 | 12:50 PM
master tech
Does the headlamps come on when you turn them on? I'm thinking you may have a ignition problem with either the switch or the battery wire going to the switch.
