[5th Gen : 08+]: Cigarette Lighter not functioning
Old Apr 29, 2020 | 09:59 PM
Landonl3's Avatar
Landonl3
Default Cigarette Lighter not functioning
I recently bought a 2018 grand caravan and I’ve enjoyed it thus far. I’ve got a problem with one of the cigarette lighters though. It’s not working. It’s the one in the center console on the right side, with the image of the battery on the cover. Anyways, I bought a new socket, because I though that was the problem, I replaced it with the old one, and it still didn’t work. Then I replaced the actual connector that connects the wiring to the socket, and that didn’t work. I know the fuse isn’t bad because when I switch it with the cigarette lighter on the left, that one still works and the one on the right doesn’t.
ive done all I know how to do. Any suggestions on what to try next? I don’t really feel like taking it into a shop to get charged a bunch for this small thing.
Thanks!
Old Apr 30, 2020 | 01:12 AM
master tech's Avatar
master tech
Site Moderator & Tech
Have you check fuses M5, M7 and M36 with a test lamp? If the fuses are good. Then you need to inspect for an open circuit or a bad ground.
