[4th Gen : 01-07]: '03 Caravan 3.3L surging....
Old May 2, 2020 | 02:14 PM
DodgeDude7859's Avatar
DodgeDude7859
Default '03 Caravan 3.3L surging....
Hi everyone--
New to this forum. Pulling a code of P0306....#6 cylinder misfiring....plug and wires look good....any other suggestions?.....thanks....
Old May 3, 2020 | 02:04 AM
master tech's Avatar
master tech
Site Moderator & Tech
Perform a compression test and see if you are getting 140 to 160 psi. And maybe switch the number 2 plug with number 6 and see if the misfire follows the plug.
Old May 3, 2020 | 01:34 PM
DodgeDude7859
thanks master tech....compression is 150psi......plug has plenty of spark.....I did the stethoscope test on the base of the injector with a long-handled screwdriver to my ear....pin is clicking nicely....I'm now thinking it might just be a clogged injector......might consider an injector cleaner.....any recommendations?
Old May 3, 2020 | 01:44 PM
master tech
I would ask one at the part store you go to and ask then for the best one they have and maybe get a price on an injector just in case.
Old May 3, 2020 | 04:01 PM
DodgeDude7859
Thanks master tech....I'm not so sure I trust the employees at my local Auto Zone.....is there any FI cleaner that you like?
Old May 5, 2020 | 01:50 AM
master tech
Then go in and pick the you like, I'm sure they all are about the same. You will add to your fuel tank. Maybe STP?
