[5th Gen : 08+]: Pcm c2 connector
Old Jan 23, 2021 | 08:21 PM
Caravan4209's Avatar
Caravan4209
Default Pcm c2 connector
He guys got in a fender bender and pcm got hit and I got multiple codes relating all to the c2 connector . Car cranks but won't start since important sensor like crank and cam all on c2 connector . None of the pins got damaged just the connectors came off. Is there a fuse for this ?
Old Jan 27, 2021 | 07:32 PM
Mark Warren's Avatar
Mark Warren
all the fuses are in the TIPM. Sometimes a wire will break away from the pin inside the connector, best to start with a continuity check on each wire.
Old Jan 27, 2021 | 08:10 PM
Caravan4209
Found pin 29 the 5 volt supply is grounded inside the pcm. I ordered a new one hopefully it will start.
Old Jan 27, 2021 | 08:14 PM
Mark Warren
Let us know the outcome. I was under the impression that the dealer has to flash a new PCM in order for it to work with the key etc.
Old Jan 27, 2021 | 08:25 PM
Caravan4209
Yes the place i ordered it flashes my vin
