[4th Gen : 01-07]: Help
Old Jan 26, 2021 | 11:42 AM
Edward Young's Avatar
Edward Young
Default Help
Hi I have a Dodge caravan 03,and whenever I tried accelerating from a park position it shuts down ,
. The engine Revs fine in neutral. Please help!!!
Old Jan 26, 2021 | 11:49 AM
IDon'tGiveARam's Avatar
IDon'tGiveARam
Do you mean accelerating while shifted into PARK or accelerating from a dead stop? If you mean from a stop then have you tried accelerating while shifted to 1,2, or 3 (or whatever there is other than drive)? How about Reverse?
Old Jan 26, 2021 | 12:40 PM
Edward Young
When at park position, putting the van from park to drive then press the pedal to accelerate it will either hesitate or shutdown
Old Jan 26, 2021 | 01:13 PM
IDon'tGiveARam
1. Try reverse and see what it does (R is a larger gear so highest engine power over transmission) -- what does it do?
2. Put shifter down to 1 (this forces the automatic transmission to use 1st gear) -- what does it do?
3. When you put it in N does the indicator on the dash land over the N or closer to R or D? (if shifter is through a cable it can wander)
Old Jan 26, 2021 | 01:16 PM
IDon'tGiveARam
Also, are you needing any tune up parts like spark plugs, air filter, or fuel filter (if you have one)?
Has the issue only happened on the current tank of gas? Could be lousy gas or have water in it.
Old Jan 26, 2021 | 01:54 PM
Edward Young
Ok will try those later, many mechanics told it's gas pump n filter that's need to change, but I'm not too sure my engine Revs great, it's like when never load is apply it's shuts down but now it's even worst I can't even accelerate from a dead stop too fast because the engine will hesitate
Old Jan 26, 2021 | 02:02 PM
IDon'tGiveARam
That is what would happen if your fuel filter we're mostly clogged or fuel pump were dying. But then again it could also be spark or air if nobody has actually gone and checked anything.
Old Mar 28, 2021 | 09:16 PM
Edward Young
Default Chrysler town n country
Hi , I got another problem
. I got a 2005 Chrysler town n country but however when using the rear AC I can't seem to turn off the floor vent they are always on when I switched on the rear AC
It also cause my top vents to blow really weak Any ideas ?
