[5th Gen : 08+]: AC reset
Old Jun 25, 2021 | 10:27 AM
skullydog's Avatar
skullydog
Default AC reset
I'm having problems with AC not cooling enough. I've been reading about resetting AC, but can't seem to get a clear picture of which buttons to push. I have a 2016 grand caravan r/t with dual zone / rear zone. No heated seats or steering wheel. Any thought or advice
Old Jun 25, 2021 | 11:59 AM
DodgeCares's Avatar
DodgeCares
Hi skullydog,
Sorry to hear you are experiencing this. We understand you are reaching out to fellow forum members, however if you are not able to remedy this concern with the advice provided here; we kindly recommend connecting with your local Dodge dealer. If you are in need of any assistance with that process, our team is available via private message.
Rob
Dodge Cares
Old Jun 25, 2021 | 05:46 PM
skullydog's Avatar
skullydog
I appreciate the answer from Rob at Dodge cares. I thought this was a place where we can share info for DIY'ers to avoid spending money at a dealership. So Rob if you know the answer or have actual advice for my situation, then tell me. I am afraid I see your reply as a solicitation. I don't do forums much, is this appropriate or common in this forum, someone tell me
Old Jun 27, 2021 | 11:04 AM
Mopar340's Avatar
Mopar340
First you can try with a/c on turn both ***** simultaneously from hot to cold 5 or 6 times to synchronize the blend doors. you can also go to an auto shop that specialize in a/c repair to check pressures to insure that the refrigerant isn't low which will cause an evaporator freeze up.
Old Jun 27, 2021 | 11:13 AM
skullydog's Avatar
skullydog
It was low on freon, but there's a definite difference in temp from one side to the other. And the problem I have resetting is that all can ever read is about tuning *****, I dont have ***** on the 2016. But thanks anyway
Old Aug 6, 2021 | 06:21 PM
zahoor's Avatar
zahoor
Check your evaporator drain pan, drain line may be plugged with dirt, once it's all clean evaporator will stop freezing. Also keep ur thermostat little higher on a v hot day, low setting may cause freeze ups.
