[5th Gen : 08+]: Changed window regulator now door won’t latch
Old Aug 5, 2021 | 02:25 AM
hotrod4x5's Avatar
hotrod4x5
Default Changed window regulator now door won’t latch
2012 Gr Caravan Title says it all:
I successfully changed the drivers window regulator, but when I reattached the two little rods that operate door latch, the door will no longer latch. I cannot figure out what is wrong. I will try and attach a video. It seems like the rod does not move the mechanism sufficiently. I have moved the flippy thing that grabs the pin, but that didn’t seem to be the issue.
https://youtu.be/AuMXTvAms30
Old Aug 12, 2021 | 10:29 PM
COMP's Avatar
COMP
does it latch with the rod disconnected ? need adjusted ?
