[3rd Gen : 96-00]: Valve body question
Old Oct 7, 2021 | 08:03 PM
Rich75's Avatar
Rich75
Default Valve body question
Hi, so I have a 96 Grand Caravan with the 3.8 v6. I recently swapped in a transmission from an '02 Caravan, because the differential on the original, crapped out on me. When installing the replacement tranny, I swapped over the speed sensors, and solenoid pack as well, because they had all been recently replaced on the old tranny. The transmission shifts pretty decent, but when I come to a stop, it feels as if I'm getting hit in the rear as it's shifting into first gear. I only feel this if I have my foot on the break as it downshift. If I let it coast to a stop, I don't feel anything. So I was wondering, if I swap out the valve body, would this resolve my issue with the harsh 2-1 shift? Thank you in advance.
Old Oct 8, 2021 | 01:05 AM
master tech's Avatar
master tech
Site Moderator & Tech
No, You need to perform a quick learn with a scanner. You should also have the dealer check any controller updates too.
Old Oct 8, 2021 | 10:00 AM
Rich75's Avatar
Rich75
so what type of scanner would I need? I've called a couple dealerships in my area, and they don't have the equipment necessary for the quick learn. I have the Zurich pro scanner from harbor freight, but I don't recall seeing an option for a transmission quick learn.
