[2nd Gen : 91-95]: no more clunk
Old Apr 19, 2022 | 10:36 PM
Dearolddadsgarageexperiment's Avatar
Default no more clunk
i found on the bolt under the exhaust manifold was super tight the others holding it to the engine were missing. fixed that with some bolts and lock washers and no more clunk. it seems to shift now but after it warms up it still pops into neutral. so i shut it off and restart it and it takes right off. i would like to drain the gas tank because the gas is getting old (1 year ) and i found the drain but i am not sure of the size of the hose or the procedure. the book says to put a container under the hose and take the fill cap off. will it just start pouring out then? the stub they give you is kinda short or should i get an electric fuel pump to pull the fuel out?
Old Apr 24, 2022 | 10:40 PM
master tech's Avatar
master tech
Site Moderator & Tech
Is this a 3.0L with a 3speed transmission or a 4 speed transmission?
Old Jul 5, 2024 | 06:40 PM
Damndodge1!'s Avatar
Damndodge1!
4 spd automatic.
