[5th Gen : 08+]: My 2010 Dodge Grand Caravan shakes, shudders, jolts forward, then idles rough
My 2010 Dodge Grand Caravan shakes, shudders, jolts forward, then idles rough when stopping quickly for stop lights. A slow stop minimizes the symptoms. Please help. I have no clue what it can be
Mode $06 report generated by Torque for Android
Vehicle VIN: 2D4RN5D12AR433273
Vehicle Manufacturer: Dodge
Vehicle Calibration ID: 68049415AF
3
Test report:
MID:$01 TID:$91
- O2 Bank 1 Sensor 1
Test incomplete or dependant test failed
MID:$02 TID:$07
Minimum sensor Voltage for test cycle(calculated) - O2 Bank 1 Sensor 2
Max: 0.607V Min: 0V
Test result value: 0.607V
PASS
MID:$02 TID:$08
Maximum sensor Voltage for test cycle(calculated) - O2 Bank 1 Sensor 2
Max: 65.535V Min: 0.647V
Test result value: 0.803V
PASS
MID:$02 TID:$81
MID:$02 TID:$82
MID:$02 TID:$83
MID:$21 TID:$92
- Catalyst Monitor Bank 1
MID:$31 TID:$93
- EGR Monitor Bank 1
Max: 50Count Min: 0Count
Test result value: 0Count
PASS
MID:$31 TID:$94
PASS
MID:$31 TID:$95
Max: 333.16998% Min: 227.67999%
Test result value: 328.97%
PASS
MID:$31 TID:$96
MID:$39 TID:$87
- EVAP Monitor (cap off)
MID:$3a TID:$87
- EVAP Monitor (0.090")
MID:$3c TID:$85
- EVAP Monitor (0.020")
MID:$3c TID:$86
MID:$3c TID:$90
Max: 4,300minute Min: 12minute
Test result value: 66minute
PASS
MID:$3d TID:$83
- Purge Flow Monitor
Max: 65,535Bool Min: 0Bool
Test result value: 0Bool
PASS
MID:$3d TID:$84
Max: 100.00641% Min: 16.40755%
Test result value: 23.43936%
PASS
MID:$3d TID:$85
MID:$3d TID:$86
Max: 1.99882 Min: 0
PASS
MID:$3d TID:$87
Max: 65.535 Min: 0
PASS
MID:$3d TID:$88
MID:$3d TID:$89
MID:$41 TID:$97
- O2 Heater Monitor Bank 1 - Sensor 1
Max: 390°C Min: 0°C
Test result value: 60°C
PASS
MID:$41 TID:$98
MID:$42 TID:$97
- O2 Heater Monitor Bank 1 - Sensor 2
Max: 165°C Min: 0°C
Test result value: 30°C
PASS
MID:$42 TID:$98
MID:$a2 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 1 Data
Max: 65,535Count Min: 0Count
PASS
MID:$a2 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 1 Data
PASS
MID:$a3 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 2 Data
PASS
MID:$a3 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 2 Data
PASS
MID:$a4 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 3 Data
PASS
MID:$a4 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 3 Data
PASS
MID:$a5 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 4 Data
Test result value: 1Count
PASS
MID:$a5 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 4 Data
PASS
MID:$a6 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 5 Data
PASS
MID:$a6 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 5 Data
PASS
MID:$a7 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 6 Data
PASS
MID:$a7 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 6 Data
PASS
End of report.
3
Test report:
MID:$01 TID:$91
MID:$02 TID:$07
Max: 0.607V Min: 0V
PASS
MID:$02 TID:$08
PASS
MID:$02 TID:$81
MID:$02 TID:$82
MID:$02 TID:$83
MID:$21 TID:$92
MID:$31 TID:$93
PASS
MID:$31 TID:$94
PASS
MID:$31 TID:$95
PASS
MID:$31 TID:$96
MID:$39 TID:$87
MID:$3a TID:$87
MID:$3c TID:$85
MID:$3c TID:$86
MID:$3c TID:$90
PASS
MID:$3d TID:$83
PASS
MID:$3d TID:$84
PASS
MID:$3d TID:$85
MID:$3d TID:$86
Max: 1.99882 Min: 0
PASS
MID:$3d TID:$87
Max: 65.535 Min: 0
PASS
MID:$3d TID:$88
MID:$3d TID:$89
MID:$41 TID:$97
Max: 390°C Min: 0°C
PASS
MID:$41 TID:$98
MID:$42 TID:$97
Max: 165°C Min: 0°C
PASS
MID:$42 TID:$98
MID:$a2 TID:$0b
PASS
MID:$a2 TID:$0c
PASS
MID:$a3 TID:$0b
PASS
MID:$a3 TID:$0c
PASS
MID:$a4 TID:$0b
PASS
MID:$a4 TID:$0c
PASS
MID:$a5 TID:$0b
PASS
MID:$a5 TID:$0c
PASS
MID:$a6 TID:$0b
PASS
MID:$a6 TID:$0c
PASS
MID:$a7 TID:$0b
PASS
MID:$a7 TID:$0c
PASS
End of report.
