[5th Gen : 08+]: Windshield wipers not working properly
Old Aug 21, 2022 | 05:56 PM
Bdg123's Avatar
Bdg123
Default Windshield wipers not working properly
Hi,
I have a 2017 caravan. Intermittently the wipers would move really slow on all settings, then work as normal. Now they stuck 4/5ths of the way up.
I got them down, removed the cowel and hit with a healthy amount of white lithium grease. They went halfway anf stopped again. I applied it at at different positions of the wipe cycle, gently moving the arms by hand. I'm letting it soak and awaiting results.
I hear the relay, motor tries without any indication of slipping, fuse is good and the switch works. Trying to avoid motor and/or assembly replacement if possible.
Any thoughts?
Old Aug 24, 2022 | 08:45 PM
Bdg123's Avatar
Bdg123
Originally Posted by Bdg123
Hi,
Any thoughts?
Was the transmission/linkage. Put a new one in and works as it should.
