[General]: Chrysler & Dodge: Drive Cycle Procedures to complete OBD Readiness Monitors
Old Sep 17, 2022 | 10:54 AM
joepeterson56's Avatar
joepeterson56
Default Chrysler & Dodge: Drive Cycle Procedures to complete OBD Readiness Monitors
Posted on January 17, 2014 by dewokChrysler Drive Cycle Information
All Monitor Drive Trace
Pre-Conditioning Requirements:
– MIL must be off
– Cold start (Note: cold start temperature is undefined)
Driving Procedure
1) Warm engine up for five minutes (must reach closed loop)
2) Drive (with steady throttle) at a speed between 40 and 60 mph for 8 minutes.
3) Stop and idle for 3 minutes.
4) Drive (with steady throttle) at a speed above 20 mph for 2 minutes.
5) Turn key off, leave off for ten minutes (to run O2 sensor heater monitor).
Note: Due to the limited preconditions provided with this drive trace, NCVECS recommends using the monitor
specific drive traces for Chrysler vehicles.
Catalyst Monitor Drive Trace
– MIL must be off.
– No DTCs present.
– Fuel level is between 15% and 85% full.
– ECT above 70º F.
– Engine must have run at least 90 seconds
– Engine between 1,350 & 1,900 rpm.
Driving Procedure
1) Idle vehicle for five minutes (to reach closed loop operation).
2) Drive with a steady vehicle speed between 30 and 45 mph for 2 minutes.
EGR System Monitor Drive Trace – Vacuum controlled
– MIL must be off.
Driving Procedure
2) Drive with a steady vehicle speed between 40 & 60 mph for 8 minutes.
EGR System Monitor Drive Trace – Electronic
– MIL must be off.
– MAP must be between 0-60 KPa.
– Engine speed between 500-850 rpm.
– ECT is above 180º F (90º C).
– No misfire temporary (pending) or matured fault present.
– A/C clutch, PS Switch and Cooling fans do not change state (turn off).
Driving Procedure
1) Idle vehicle for five (5) minutes (to reach closed loop operation).
2) Drive with a steady vehicle speed between 40 & 60 mph for 2 minutes.
3) Idle vehicle for three (3) minutes.
Note: This monitor evaluates EGR flow based on a change of engine roughness (idle stability).
Conditions causing un-stable idle will prevent this monitor from running.
Evaporative System Monitor Drive Trace
Trace 1: Standard Type
– MIL must be off.
– No Evaporative DTCs present.
– Fuel level is between ½ and full.
(Note: monitor may still run with tank fill between 15% and 85%).
Driving Procedure
Trace 2: Leak Detection Pump
– MIL must be off.
– Fuel level is between 30 & 85 % full.
Driving Procedure
1) Cold soak vehicle, start and idle vehicle for 4 minutes.
2) Drive in-town (stop and go) for 5 minutes, using smooth accelerations and decelerations.
3) Stop and idle vehicle for 4 minutes.
O2 Sensor Monitor Drive Trace
– MIL must be off.
Driving Procedure
2) Drive with a steady vehicle speed above 25 mph for 2 minutes.
3) Stop and idle for 30 seconds.
4) Smoothly accelerate to a speed between 30 and 40 mph.
5) Repeat steps 3 & 4 five (5) times.
O2 Sensor Heater Monitor Drive Trace
– MIL must be off.
Driving Procedure
2) Shut engine off and leave vehicle off for ten minutes.
