[General]: Dodge caravan SE
Old Oct 2, 2022 | 10:09 AM
Kapl550's Avatar
Kapl550
Default Dodge caravan SE
Hi,
I have had an issue with my Dodge Caravan 2013 which seems to be the general consensus that it’s an electrical issue. However they can’t get the car to Starr they put a new TCM, they put a Tipm in They put a new starter in and they keep coming up with codes. The car will not crank on. Here are the codes that are coming up now. PCM P0688 | Stored ASD/Main Sense Circuit PCM P0622 | Stored Generator Field Control Circuit/Open PCM P0706 | Stored Transmission Range Sensor Rationality.What advice can you give to get this car working? Thank you
