[5th Gen : 08+]: 2010 brake/turn signal issue
Old Mar 26, 2023 | 02:19 PM
Beavis519's Avatar
Beavis519
Default 2010 brake/turn signal issue
I have had some issues recently with the brake/signal indicator bulb not working. Replaced bulbs worked for a while. Finally replaced the sockets on both sides and everything was fine for a couple months. I think I have figured out the issue, but not the cause.
Fresh start after sitting for a day the turn signals work fine. Step on the brake and then the signal and brake lights fail to work. I'm assuming there is a ground short in the brake line. Other ideas are welcomed, thank you.
Old Mar 30, 2023 | 11:03 AM
Beavis519's Avatar
Beavis519
Turns out this whole debacle was the result of double filament bulbs being used for the reverse lights, which required single filament bulbs. I never changed them since I acquired the van and the weird part is I've had the van for 3 years now.
