[2nd Gen : 91-95]: 1995 plymouth voyager compression piston rings
Dodge CaravanThe Dodge Caravan is the best selling mini van from Dodge. How many Dodge Caravan owners here at DodgeForum.com would agree? Discuss it now!
I think I have found the problem with my vehicle, compression. But I am not quite for sure what is causing the compression loss. I don't think it is the valves because I did leak test and some of them were good. I also do not think it could be the head gasket. That leaves me with the rings. Is their any sure way to test the rigs to see if they are the cause. Or is their anything else that could cause loss of compression.
Do a compression test, test all cylinder dry first, then, add a teaspoonful of oil to each cylinder, one a time, and test them again. If the numbers jump considerably, bad rings.
