[5th Gen : 08+]: 2010 manual sliding door unable to open from inside (not child lock)
Old May 28, 2024 | 12:46 AM
story1234's Avatar
story1234
Default 2010 manual sliding door unable to open from inside (not child lock)
Hi, I just picked up a pre-owned 2010 Caravan SE. It doesn't have power windows or power sliding door. I cannot open one of the door from inside. I thought it was child lock but it's not. It's also not the unlock/lock button. The door can be unlocked from the outside. Here's the difference between a child lock door from the working sliding door. The working door will pull further and have click. The non working door will have half the pull and no clicks.
I haven't been unable to find a similar problem elsewhere.
Old Jul 23, 2024 | 05:05 AM
rosstanos's Avatar
rosstanos
Try to rest it with 15 minutes
The sliding doors have now been fixed on both sides What should be done to fix it? By using the lock and unlock function on the driver's side Once the child lock is engaged, push and pull it at the same time!
