[5th Gen : 08+]: 2008 Grand Caravan 3.8 SXT coolant issues
Old May 30, 2024 | 05:35 PM
Vicky H's Avatar
Vicky H
Default 2008 Grand Caravan 3.8 SXT coolant issues
Hey all, thanks for your time. I have 2008 grand caravan 3.8 that was spewing coolant out of the reservoir. Never actually overheated, in fact the rad cap wasn't even hot. Radiator changed in 2019. I just changed the radiator cap and thermostat. I can sit and idle for 30+ minutes with no problems. If I try to drive a distance is when is starts smoking again and spewing. I'm here from Florida house hunting and need to drive around. Coolant sensor? I did notice droplets on the y tube opposite of the thermostat. All my tools are in the POD sent up here but I know I can borrow some but I need to know what I'm looking at. Oil is clean and no coolant cloud out of exhaust. I sure could use some advice and suggestions. Thank you .
Old May 30, 2024 | 06:55 PM
How long ago did you change the radiator cap? Some of the aftermarket fellers don't seal real well.... May wanna check the oil as well, see what it looks like.
Old May 31, 2024 | 09:48 AM
Vicky H's Avatar
Vicky H
I changed the radiator cap just last month. I put the radiator in fall of 2019. Oil looks good and no coolant cloud from exhaust.
