[General]: Keyless entry
Old Sep 6, 2024 | 12:29 PM
Tito636's Avatar
Tito636
Default Keyless entry
Hey all,
I have a 2005 Dodge Grand Caravan that I would like to install a keyless entry. I bought the module and installed the resistors so everything is ready to go. If I connect it to the wire inside the door it will work. The problem that I am having is trying to locate the wire inside the van. I found one install sheet on the internet that says to connect it to plug 3 pin 21 on the BCM but I can not find a pinout for the BCM to locate it. Does anyone happen to have a pinout for the BCM or is there a better place to terminate the wire?
