[5th Gen : 08+]: all injector codes 2014 caravan
Old Oct 20, 2024 | 06:07 AM
wog111's Avatar
wog111
Default all injector codes 2014 caravan
I had a mouse chew and short out one injector circuit, right at the injector, both wires slightly touching. I repaired the damages wires and checked others.
I now have p0201,p202,p203,p204,p0205,p0206 open circuit and sometimes a misfire code. it does run, with a slight misfire, so i don't think the ecu drivers were damaged?
Has anyone run into this?
Old Oct 22, 2024 | 12:27 AM
master tech's Avatar
master tech
Site Moderator & Tech
Check and see if there is an injector harness replacement from the dealer. There could be other problems with the wires. And yes the shorted wires could have damage the PCM or engine controller.
Old Oct 22, 2024 | 09:21 AM
wog111's Avatar
wog111
Thumbs up all injector codes
Thanks, I will check. I think i will also hook up injector noids and see if anything looks strange, although im not sure if there is room for them on this engine?
