[5th Gen : 08+]: 2010 Dodge Caravan Power Outlet #2 (Batt/Acc select) stopped working suddenly
Old Nov 6, 2024 | 09:49 PM
story1234's Avatar
story1234
Default 2010 Dodge Caravan Power Outlet #2 (Batt/Acc select) stopped working suddenly
My Caravan’s battery always live outlet suddenly stopped working.
I bought a 12v heater that pulls 150w. The live power outlet is the only spare outlet so I turn it off when I get out of the car. I forgot to turn the heater off ran on battery for 5 mins and the power outlet no longer works. I checked the fuses, replace the fuses M7, M6. The two ignition outlet works and that’s including the second row ones.
I check the M7 fuse slot and there's no voltage.
I did a hard power reset as well. No one else seem to have this problem.
Old Nov 7, 2024 | 11:56 PM
master tech's Avatar
master tech
Site Moderator & Tech
Did you check all fuses for power and ground? And are you using a test lamp, power probe or load tester?
Old Nov 8, 2024 | 10:00 AM
story1234's Avatar
story1234
The fuses are switch around with working fuse outlet and confirmed all fuses are working.
I have a voltmeter. I connect positive one side of fuse slot and the other to negative ground. There’s no voltage.
Old Nov 15, 2024 | 02:33 PM
master tech
You could have a wire that has back out of the slot in the PDC/Fuse box. I would do a continuity test on that circuit and make sure you don't open circuit.
Old Nov 26, 2024 | 11:23 PM
story1234's Avatar
story1234
It happened again. This time on outlet 3 and the fuse is also not blown. Could the wires have melted?
I haven’t remove the fuse box to check wires yet.
update:
It was the Ecoflow. I had to limit the input to 6A instead of 8A and no fuse blown.
Old Oct 10, 2025 | 03:43 PM
story1234's Avatar
story1234
Default Fixed
Alright so I finally bought the replacement outlet and the tool to get it out. There’s continuity in the old outlet and there’s voltage so I plug it back in and it works. Same goes for the live Power Outlet, unplug and replug and it started to work. I made sure to test it before I unplug and it wasn’t working.
