[5th Gen : 08+]: Van leaking and found this part on engine case
Old Dec 10, 2024 | 02:00 PM
KingSoulja's Avatar
KingSoulja
Default Van leaking and found this part on engine case
Anyone have idea of what it is so I can replace it ASAP i belive it's causing my leak
Old Dec 11, 2024 | 12:45 PM
master tech's Avatar
master tech
Site Moderator & Tech
Did you remove this from this sensor from the engine on the back side of the block near the drive axles? If you did that would be a crankshaft sensor.. Do you have a picture from where you removed from?
