[5th Gen : 08+]: Grandcaravan 2014 30th year edtion sxt HELP!!!!
Old Dec 26, 2024 | 01:20 PM
Milenko417's Avatar
Milenko417
Exclamation Grandcaravan 2014 30th year edtion sxt HELP!!!!
Hello and good to you reading this. i am in a pickle here and completely stomped on what to do. the van will not fire off at all. when you get in the van and insert the keys. every turns on like it should and will. when i hit the start with the key. the radio blacks out and it seems to do like a reset . then the radio comes back on and the check engine light flashes 3 times. i have no idea where to even look any more
1 changed the starter think it was that . it wasnt
still does the same problem
2. check the PCM for the relays and fuses all good. tried a jumper cable to see if it was a bad relay and checked with volt meter
still the same problem
3. check ground wires. i found 1 tethered ground wire from the motor mount to the frame fixed it\
still same problem.
4. was told that this van has 3 different grounds. i have looked and looked and i just dont know where to look at this point.
5. all the research i have done is leading me to either the ground wires still being bad. or the ECM or even the ignition modular is no good.
my biggest question is have anyone else every delt with problem or even heard some thing like this? please help me with this if you can. this is my wifes and i only transportation at the moment and its really hurting finding rides to work. please help if you can
