Caravan trans help....
Old May 10, 2004 | 09:30 PM
MartinLG3's Avatar
MartinLG3
Default Caravan trans help....
I just bought a 1994 Grand Caravan SE on the cheap. It runs pretty good, has about 126k, the only problem is that it has no REVERSE. The transmission sounds like it's engaging when I put it in reverse but it just won't go anywhere. All the other gears seem to be fine. Any help would be appreciated.
Old May 10, 2004 | 11:58 PM
dodgemech's Avatar
dodgemech
Default RE: Caravan trans help....
bad news charlie brown, you have typical seal failure, internal trans. Since all the other gears work I would guess the rev seals in the input hub are leaking.
Old May 11, 2004 | 08:57 PM
MartinLG3's Avatar
MartinLG3
I found a transmission pretty cheap today. How hard would it be to replace it?
Thanks again!
Old May 12, 2004 | 04:43 AM
dodgemech's Avatar
dodgemech
Pretty easy on a hoist with a trans jack. At home on the driveway---I don't know about that, the trans is in there at a very steep angle and requires a bit of "finese" to get evrything to drop in place. At the dealer we only charge about 550 labor and thats at 135/hr. You could probably find an independent to do the job for a few hudred bucks.
