Now I have issues!!
now i have issues
#1 rear hatch lock "flutters" every other time sometimes evertime!
some one told me about a lock adjuster???
can I do this or is it a ASE mechanic job and out more $$$
#2 rear wipers do not work is there another code sequence to turn them on
I even went so far as to replace the motor to no avail!
#3 front overhea dome light flutter from time to time??
ideas
anything will help me out
thanks
[IMG]local://upfiles/4599/Nl293899518.jpg[/IMG]
ideas
thanks
Year and model are a big help!!!!
1)If the rear latch "flutter" is when u lock or unlock the doors u need a latch assy, easy job
2)If your rear wiper motor failed and set a code, the BCM will need codes cleared (battery disconnect) before it will work
3) bulbs are cheap, try that first
