Dodge 1995 high beam light always on
My high beam light is always on and it is like the problem is in the Turning and Cruise Control switch. The light high beam lights does not go off on removal of the fuses. Now I have to disconnect the front lamps in order not to run down the battery. The information center keeps showing the high beam light even when the ignition is off.
Who has had a similar experience? Would replacing the Turning and Cruise Control switch solve the problem?[/size]
