3.0 to 3.3 swap
Old Sep 18, 2006 | 09:51 AM
cam67's Avatar
cam67
Default 3.0 to 3.3 swap
I was just wondering if I could put a 3.3 motor and trany in my 2000 caravan it has a 3.0 in it, but it’s blown. I was just wondering if the the frame is the same so it will just drop it....
Old Sep 18, 2006 | 09:55 AM
brandoncrone's Avatar
brandoncrone
Default RE: 3.0 to 3.3 swap
It will fit, you could even go with a 3.8L if you wanted. You will need the complete engine wiring harness, PCM, catalytic converter, AC compressor, some of the refrigerant hoses amd the radiator (3.3L is bigger)
Old Sep 19, 2006 | 12:00 AM
cam67's Avatar
cam67
That cool I would rather 3.8 cuz ill be towing a small trailer with the van thank for your help...[sm=smiley20.gif]
Old Sep 19, 2006 | 01:25 AM
richardh05k's Avatar
richardh05k
Get a good transmisson external cooler and plan on changing the tran oil every 10000 miles if you tow anything. I tow and learned the hard way that dodge never designed the trans for that much work.
Old Sep 19, 2006 | 08:08 PM
minivanin's Avatar
minivanin
all you would really need would be the engine, engine harness, trans, & possibly the radiator
welcome to the the 3.3/3.8 world, enjoy the power & durability
-greg
