Rear blower noise and 3.3 thermostat ?
I like to never got logged on for some reason and I tried searching first.
Wife's 2000 caravan 3.3 stopped warming up so I knew I had to change the thermostat.
When I removed the water neck the thermostat was in pieces, luckily I found all
the pieces. Is this common ? Pulled the new one from the box and noticed the
hole in the thermostat is not centered, it is offset. Checked the original one
and it was too. I didn't notice what way it was sitting in the engine. It looked
like it wouldn't make much if any difference so I put thermostat closet to the engine.
It seems to be running normally. Does everything have to be
crazy and complicated on these darn FWD PIA ? What would the offset be for ? I can't see
it making any difference, why wasn't the thermostat centered as every other one I have ever seen has been ?
The only possible thing I can think of is they were trying to promote better flow because the water outlet is sitting
to one side of the engine. After thinking about it I believe I have it installed where it wouldn't quite flow as well as
they intended but it works perfectly. Anybody run into this ?
Second issue.......rear blower motor making noise till it warms up. I am thinking bearings ?
She also just noticed it only runs in high from all control locations. I read about the resistor block
being bad causing this. Course Dodge says you can't replace just the resistor block. If it's a resistor
it can be replaced . Anybody looked at this thing ? I know a reputable shop that can get bearings and check the motor
out for me cheap but I need to know if the resistor block can be replaced from a junk yard one or not.
Aftermarket blower motor is 298.00 plus tax.
Thx for all your help.
Bill E.
Bill E.
RE: Rear blower noise and 3.3 thermostat ?
i dunno about the blower, but the thermostat is offset to make room for the little check valve ball to help bleed air out of the system
i drilled my check ball out, & opened the existing hole to the next size larger hole, & dropped running temps approximatly 20-25* running around
-greg
-greg
