Cooling Fans Killing my Battery
Old 02-18-2007, 07:02 PM
courtom's Avatar
courtom
courtom is offline
Default Cooling Fans Killing my Battery
After I turn off my van , sometime later the fans are coming on and runnig until my battery is dead. Can anyone help ?
Old 02-19-2007, 10:30 AM
brandoncrone's Avatar
brandoncrone
brandoncrone is offline
Default RE: Cooling Fans Killing my Battery
What kind of vehicle do you have? Some of the minivans had a bad cooling fan relay module.
Old 02-19-2007, 11:30 AM
courtom's Avatar
courtom
courtom is offline
Sorry, I'm new to the site. I have a 2004 Dodge Caravan. It also does not do it every time I drive. I am wondering if the coolant temp sensor is sticking. Is this possible ?
Thanks for the reply, Much Appreciated
Old 02-20-2007, 10:08 AM
brandoncrone
Most likely is the cooling fan module that mounts to the front bumper behind the grille. To the center of the drivers side headlight. It riveted to the bumper,.
Old 02-21-2007, 08:55 PM
courtom's Avatar
courtom
courtom is offline
Changed the cooling fan relay module on bumper. Didn't fix problem. Now the fans run all the time. I have to pull fuse each time I shut of engine. I am thinking it may be the temp sensor ?
Quick Reply: Cooling Fans Killing my Battery
