1998 GC front hum noise, it's not the bearing I would think
Old Feb 26, 2007 | 09:00 PM
kabhatti's Avatar
kabhatti
Default 1998 GC front hum noise, it's not the bearing I would think
Ok, here's the deal, the noise remains constant no matter if swearving and even with the engine off. It can't be the bearings, in that case. So what else is there to check. Could it be the front hood spoiler and it's wind noise? Starts almost immediately, around 20 mph. Any idea's? Thanks,
Old Feb 27, 2007 | 02:50 PM
floorslayer1's Avatar
floorslayer1
Default RE: 1998 GC front hum noise, it's not the bearing I would think
tire noise
Old Feb 27, 2007 | 03:25 PM
kabhatti's Avatar
kabhatti
Nope, not tires, they are almost new, off my other van which was very smooth.... I may try and remove the air deflector on the hood and see if that's it.
Old Feb 28, 2007 | 12:38 AM
kabhatti's Avatar
kabhatti
Well, I've eliminated the front hood spoiler. I took it off, the steady hum is still there. I did some other tests and the hum does not change when the brake is applied either.
Old Mar 10, 2007 | 04:00 PM
Utrecht's Avatar
Utrecht
Transmission most likely ring and pinion noise.
