'03 GC - Transmission Downshift Bump
Old Mar 30, 2007 | 07:32 PM
  #21
fperezal's Avatar
fperezal
Default RE: '03 GC - Transmission Downshift Bump
How much they charged? Which computer are you refering to...tranny computer?
Old Aug 16, 2014 | 03:45 PM
  #22
trennr's Avatar
trennr
Pretty old Thread...
Originally Posted by hemmi
I've started to get a hard bump everytime the tranmission shifts down from what's seems to be second gear. I have no other problems with the transmission. Everything else is smooth! 100k on it.
but my 2003 Grand Caravan with a 3.3L is behaving exactly as original posters...
Tried replacing the TPS as suggested...
Well, I got the word from the dealer. They said:
1) replace the throttle position sensor
2) perform a throttle bottle service/cleaning
I am going to replace the sensor ($32cad) and go from there. Anyone have any instrucions or know if its a hard job?
This did not cure my issue though. (only $23 usd from Auto Zone)
and the job took me about an hour.
For a 2003 this van only has 69,000 miles.
Transmission Fluid seem clean and at proper levels.
Any other suggestions?
Could it be the Transmission Control Module?
Main Computer is not sending any codes out... is there another system Computer I should be able to check?
Old Aug 17, 2014 | 08:39 PM
  #23
2therock's Avatar
2therock
Go to the dealership or a transmission shop that has the scanner that can perform a trans relearn.
Also before this have a look at your trans oil pan and see if its wet (appears to be leaking).
A common symptom on these vans is the shift solenoid pack will crack and leak and it will look like the trans pan gasket is leaking.
If so spray some gunk on the warm area and clean it off super good and then after its dry drive it a few minutes and look for the source.
I used a flashlight and mirror but seen its not the pan.
I changed the pack.
I still had the occasional shift bump, mostly when letting off when it had already made up its mind to either shift up or down but its a rude experience.
After the relearn it shifted so smooth I could hardly tell it was shifting. Very nice.
Old Aug 20, 2014 | 10:43 PM
  #24
trennr's Avatar
trennr
I changed the pack.
Yep that was it... thanks
