2001 Grand Caravan "P0601" code
Old Aug 24, 2004 | 07:43 PM
cantman's Avatar
cantman
Default 2001 Grand Caravan "P0601" code
Does anybody know this code? My 2001 Grand Caravan 3.8l engine light came
on a few days ago. I took it to a friends garage and threw it on the code reader
had a P0601 code. (Internal control module/memory check sum error) Has anyone ever
experienced this code? Any help appreciated!
Old Aug 26, 2004 | 09:38 PM
Hemi Powered Ram's Avatar
Hemi Powered Ram
Default RE: 2001 Grand Caravan "P0601" code
You'll need to replace the PCM (internal problem)
Old Jan 4, 2005 | 11:34 PM
jack44456646's Avatar
jack44456646
Has anyone had this code on anything else, besides the caravan. I've got a Dodge Ram Wagon3500 and this code showed up recently. Is it possible to flash the bad PCU with new software and not have to buy a new PCU?
Old Jan 26, 2010 | 07:36 PM
vladhed's Avatar
vladhed
What about ignoring it? My Caravan has one and the dealer said if we only use it for local driving to just ignore it. If the PCM does fail causing the car to die, replace it then. Otherwise he said people drive around with that code for years and nothing goes wrong.
Old Jan 26, 2010 | 07:43 PM
master tech's Avatar
master tech
Site Moderator & Tech
Try doing a flash first, If it doesn't work, then you need to replace the PCM anyway.
Old Jun 8, 2011 | 04:49 PM
tmckinney's Avatar
tmckinney
I have a 2001 Caravan with the same error (Internal control module/memory check sum error)
How do you flash the computer?
Thanks,
Tom McKinney
