Dodge Challenger Forum for the 2008+ Challenger. This includes the SE, SXT, R/T, Shaker, Scat Pack, SRT and Hellcat models.
Cooling problem
Old Nov 6, 2013 | 07:00 AM
Dodge71's Avatar
Dodge71
No, I haven't tried a 180 degree thermostat. My mechanic usually uses a 160 degree thermostat and sets the fans to come on around 170 or 180 degrees. Hasn't had a problem with any other car but mine...figures. Thanks for the suggestion and I will keep the 180 degree thermostat in mind.
Old Nov 7, 2013 | 06:54 AM
lxman1's Avatar
lxman1
Site Moderator
Do you have a clutch fan?
Old Nov 8, 2013 | 02:36 PM
Dodge71's Avatar
Dodge71
No. I have 2 12" electric fans mounted behind the radiator with a fan shroud. These fans are set to come on at about 170 or so degrees. I also have a 16" pusher fan mounted in front of the radiator controlled manually with a toggle switch under the dash. More of an insurance policy with the 16" fan so I can turn it on only when I need it.
Old Nov 8, 2013 | 03:34 PM
lxman1's Avatar
lxman1
Site Moderator
Ok. Sounds like the radiator just isn't sufficient to cool properly.
Old Nov 8, 2013 | 08:21 PM
Daves69's Avatar
Daves69
Wow, I would think a new 26" 3-row aluminum radiator with two shrouded 12" fans should cool that with no problem. How can you tell if your getting flow through all three cores?
Old Nov 10, 2013 | 04:42 PM
Dodge71's Avatar
Dodge71
I don't know. I can you tell if you are getting flow through all 3 rows?
Old Nov 12, 2013 | 10:05 PM
lxman1's Avatar
lxman1
Site Moderator
Is it a cross flow or vertical flow radiator?
I am curious if the 16" fan in the front of the radiator is actually blocking airflow since you already have 2 12" fans on the other side.
Old Nov 13, 2013 | 07:04 AM
Dodge71's Avatar
Dodge71
Not sure about cross flow vs. vertical flow. It is a Champion radiator (http://www.championradiators.com/). The 16" fan was added when we were trying different things to solve the cooling problem. Since I had already spent the money to install it, I thought I would leave it in place and wire it to a toggle switch rather than pay to have it removed. I doubt that it is blocking enough airflow to make a differnce (not sure though). The car is parked for the winter so we will see how it does in the spring. Thanks.
Old Nov 14, 2013 | 12:06 PM
lxman1's Avatar
lxman1
Site Moderator
A vertical flow has the radiator cap in the center and a cross flow the the cap on the far left or right. Most Mopars have the cap in the center and are vertical flow.
Update here when you get it out of hibernation.
Jimmy
Old Nov 15, 2013 | 06:58 AM
Dodge71's Avatar
Dodge71
Thanks for the info. The radiator cap is in the center. Will be back in-touch in the spring and let you know how it is doing. Thanks.
