Dodge Challenger Forum for the 2008+ Challenger. This includes the SE, SXT, R/T, Shaker, Scat Pack, SRT and Hellcat models.
Turn signal problems
Old Nov 14, 2019 | 06:42 PM
Keithew's Avatar
Keithew
Default Turn signal problems
My 2012 challenger's passenger side turn signal was flashing faster than normal figured out the tag light was out. I replaced it and now the turn signal only works sometimes how can i fix this issue
Old Nov 14, 2019 | 07:22 PM
Recheck the bulb you replaced...... make sure you didn't disturb any other wires. (especially grounds....)
Welcome to DF!
Old Dec 2, 2019 | 07:51 PM
Keithew's Avatar
Keithew
thanks i just wiggled the wires and it started working again figured it was a loose wire or connection i cant duplicate the problem so idk still works though
Old Dec 27, 2019 | 09:51 AM
tomdel45's Avatar
tomdel45
Default signal not blinking
i have a 1997 dodge ram pick up the right signal does not work all lights are working left signal works so does the emergency lights work
any ideal what would cause this?
Old Dec 27, 2019 | 07:15 PM
You really wanna be in the 2nd gen ram section for that question.....
Do any of the lights come on when you hit the right turn signal?
Old Dec 27, 2019 | 07:43 PM
tomdel45's Avatar
tomdel45
yes all the light come on
Old Dec 27, 2019 | 07:44 PM
tomdel45's Avatar
tomdel45
yes all lights come on
Old Dec 27, 2019 | 08:03 PM
If they come on, and just don't blink, replace the flasher unit. It's in the fuse block on the drivers side of the dash.
Old Dec 27, 2019 | 08:07 PM
tomdel45's Avatar
tomdel45
did that and also replaced all bulbs did notice that the rear looks a little dim not as bright as all the rest going to try and check the voltage on the one that looks a little dim and compare it to the others
Old Dec 28, 2019 | 08:22 AM
Check the grounds as well.
Keep in mind, the 97 should have two flasher units, one for the turn signals, and one for the four-way flashers.
