Dodge Challenger Forum for the 2008+ Challenger. This includes the SE, SXT, R/T, Shaker, Scat Pack, SRT and Hellcat models.
Ticking noise doesn’t go away
Old Jul 8, 2021 | 09:41 PM
Dcar83483's Avatar
Dcar83483
Default Ticking noise doesn’t go away
5.7 heminStarts ticking at cold start up and doesn’t go away until you shut the engine off. Any idea what’s going on?
Old Jul 9, 2021 | 07:26 AM
The famous Hemi tick. But, have you checked the oil level? When's the last time the oill was changed?
Old Jul 9, 2021 | 06:48 PM
Dcar83483's Avatar
Dcar83483
It doesn’t sound like the famous hemi tick and I don’t need an oil change. Could it be something else?
Old Jul 10, 2021 | 11:28 AM
master tech's Avatar
master tech
Site Moderator & Tech
How is the engine running and do you have any codes? On the Hemi motor they do have oil squirt jets that lube the pistons from the bottom and sometime you can hear a ticking sound from that. Or you either have a lifter, push rod or a flat camshaft. That is why I was asking how the engine was running.
Old Jul 10, 2021 | 01:49 PM
Dcar83483's Avatar
Dcar83483
I don’t really know about the engine. I just know it’s sluggish and I do oil changes as needed. I don’t have any codes for sure. They checked that for me at the dealership during the last oil change 6/20 and know that that’s something they told me specifically.
Old Jul 10, 2021 | 07:29 PM
master tech
Does the engine feel like it misfiring, mostly above an idle? You could lift the intake manifold and remove the oil control valve that is bolted to front of the motor. Inspect the screen on the valve, if the screen is missing. Replace the valve and change the oil and filter. This is a recommendation not this your cause. If the engine is running fine and no DTC (engine codes) I would wait to get more intel from the dealer if they are looking into this. Also have them check Online bulletins from dodge. Or also known as TSB's.
Old Jul 16, 2021 | 09:51 AM
DodgeCares's Avatar
DodgeCares
Hi Dcar83483,
Please be sure to keep us posted as you continue to monitor this. If you find yourself having to work with your dealer, we're more than happy to get you connected with case specialists who can work alongside your dealers to explore all potential solutions. Feel free to follow up with us via private message if this would be of interest.
Rob
Dodge Cares
